- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- GT35 Variant
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- FP alluminum intake pipe, Alluminum sheet metal intake manifold, PW GT3582r Turbo w/ 0.63 A/R turbine housing, FLspeedfab top mount turbo manifold w/ bumper/hood exit exhaust/wastegate dump, RTM aluminum duel in-tank fuel pump hanger/sending unit w/dual Walbro 255LPH pumps rewired, -8AN SS braided fuel feed, -6AN return line, FuelLab in-line filter, FuelLab AFPR, FIC 1150cc injectors, Full emissions delete, Godspeed FMIC w/ 2.5" piping, Knock off greddy BOV custom diaphragm, A/C delete, JayRacing saturn alternator relocation, Custom 3" v-band bumper dump exhaust pipe, Modified Knock off greddy catch can from 2 -10AN fittings welded in valve cover, Prothane motor mount inserts, Devils-own methanol injection 10 GPH nozzle, Greddy magnetic oil drain plug, Hallman pro MBC
- Mods-Engine
- Eagle forged 100mm Crankshaft polished, ARP main studs, Eagle H-beam Connecting rods, ARP rod bolts, Wiseco 9:1 forged pistons, ACL Race main and rod bearings--standard size, Kiggley girdle, Balance shaft delete, OEM Straight cut oil pump gears in OEM front case, Felpro permatorque MLS head gasket, Cometic gaskets all around, 1g Cylinder head ported/polished, SBI 1mm oversized SS valves, Bronze valve guides, Manley valve springs, Titanium retainers, DKS 272/272 camshafts, fidanza adjustable cam gears, ARP head studs, Kiggley HLA oil pressure regulator
- Mods-EMS & Logging
- ECMlink v3 speed density w/ GM IAT sensor, Omnipower 4 bar MAP sensor, Autometer boost/vacuum gauge, Apexi turbo timer, Innovate MTX-L wideband, Glowshift oil pressure gauge - sending unit relocated with -4an braided SS lines
- Mods-Drivetrain
- 2g shift knob, Stock 1g 23 spline trans., Welded center diff, Fidanza lightweight flywheel, Southbend SS-X-Series Pressure Plate, ACT 6-puck sprung clutch disc, SBC Throwout Bearing, Brass cable bushings, Alluminum shifter plate bushings, SS braided clutch line master to slave, OEM slave cylinder w/ restrictor removed, Forged steel competition clutch fork and pivot ball
- Mods-Handling
- Ksport kontrol coilovers, Wedsport SA70 wheels
