- Ownership Status:
- Currently Own
- Turbo Type:
- 16g
- Drivetrain:
- AWD
- Transmission Type:
- Manual
- Build Type:
- Street
- Mods-Bolt-on:
- ⁃ Evo ported exhaust mani
⁃ Evo ported o2 housing
⁃ Slow boy racing FMIC
⁃ Tail 50mm BOV
⁃ Custom catch an setup with moroso vented can.
⁃ Front facing oil filter housing with SS -an lines to aftermarket oil cooler
⁃ Sheptrans stage III TRANS
⁃ Quarter Master vdrive twin disc
⁃ 4 bolt posi rear
⁃ Chromoly tubular front cross member
⁃ Energy suspension motor mount inserts
⁃ Jays racing alternator relocation kit
⁃ FD Rx7 wheels 13.8 lbs
⁃ Auto meter boost gauge 45 psi
⁃ Auto meter EGT gauge tappet into header
⁃ ECM link V3
⁃ Speed density setup
⁃ Innovative motor sports LC-2 digital Wideband
⁃ Fuel injector clinic 950cc injectors
⁃ Aeromotive adjustable fuel pressure regulator
⁃ AN SS braided lines from fuel tank to injector rail (feed & return lines) earls AN fittings
⁃ Dual Bosch 044's in tank
⁃ Mahle pistons
⁃ Eagle rods
⁃ ACL race bearings
⁃ Brian crower 272 cams
⁃ Brian crower valve springs and titanium retainers
⁃ SS valves
⁃ ARP head studs
- Background:
- Bough the car with the mods on it. Going through it to clean it up and get it running.
Join the Community!
Comments
Sort Comments By
