1997 Mitsubishi Eclipse GSX Vehicle Profile & Build Thread
Clipse90Turbo's Eclipse GSX
2G GSX:
2g Non-Turbo
Aftermarket Headers
2.5'' Cat-back Exhaust
Cold-Air Intake
Last Project:
T3/T4 Turbo Compressor: 50 A/R, Turbine 63 A/R, Trim 57 - T3/T4 Tubular Manifold with Tubular O2 housing and Open Dump - Tial 38mm Wastegate -turbosmart MBC - Performance Intake Manifold (Similar to Venom) - 1990 63mm Throttle Body - FMIC with piping (Blitz SS BOV) 3" GM MAF and MAF-T - 3" Thermal research turboback exhaust - FIC 850cc injectors - 255lph fuel pump with install kit - Aeromotive Fuel Regulator Kit w/ gauge - Apexi S-AFC II - 1990 EPROM with Stage 3 Chip - Color Data Logger - Greddy EGT Gauge - Autometer Boost Gauge, Autometer Oil Pressure Gauge -Limited Slip Differential (Quaife) rebuilt tranny - eclutchmasters.com Stage 2 racing clutch -
Fidanza 6-bolt Fly
Mods-Engine
97GSX:
2G: Stock
1G:
JE Stroker Pistons 8:5:1 (.20over)
Eagle H-Beam Connectin Rods
2.4L Stroker Crankshaft
Comp Cams 101200 series
Crower Valve springs and stock retainers
Arp studs and bolts
Cometic Headgasket
Polyurethane Motor Mounts.....
17x7 White Motegi Rims w/ Toyo Proxes 225/45/17
Drilled/Slotted FR/RR rotors
KYB GR-2 Struts with cut springs
Parts Wishlist
Big Brake Kit, better suspension, Lambo doors, CF Invader Hood, M3 Style Mirrors (just got them), Racing seats, Roll-Cage......
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
2G DSM
Clipse90Turbo
More in 2G DSM
Share this vehicle
