1. Join the Community!
Showcar Build Celtic Blue awd swapped 2.0L hx-40
Year:
1997
Model/Trim:
Mitsubishi Eclipse GST
  • Ownership Status:
    I own it
    Drivetrain:
    AWD
    Transmission Type:
    Build Type:
    • Showcar
    Mods-Bolt-on:
    FP 4" intake, apexi power Intake
    Hallman Pro MBC
    1350cc FIC (flow tested@1420cc)
    FuelLab AFPR
    Rewired 255 walboro in-tank, 255 walboro in-line
    6an all the way to the tank
    AEM fuel rail
    Speed density
    JMFab T3 manifold, 38mm tial external WG
    HX-40 7-blade KTS, T3 .70 BEP housing
    Thermal R&D 3" catback
    STM 3" downpipe
    Evo 3 Intake Manifold
    Throttlebodys.com 1gnt tb w/ halfshaft mod
    VRSF intercooler (required me to use 2gnt overflow)
    Tial 50mm BOV
    custom catch can
    Mods-Engine:
    '97 7-bolt, BSE, oil port mod 1&2
    8.3:1 Wiseco + Eagle H-beam
    Eagle 7-bolt crank, ACL bearings
    OEM oil pump, Kiggly HLA
    Kelford 272/272
    Ferrea 6000 series valves, beehive springs, retainers, and locks
    Evo 9 lifters and rocker arms
    Stock head gasket
    ARP L19's
    Fluidampr Harmonic Damper
    Evo 9 OFH
    Mods-EMS & Logging:
    ECMLink v3
    AEM boost gauge 50psi
    AEM oil pressure 150psi
    AEM wideband o2
    Mods-Drivetrain:
    GS-T with AWD swap, LSD rear
    TMZ trans (no info from gsx owner, definitely built)
    ACT Streetlite flywheel
    Southbend Ceramic HD clutch
    Magnus t-case billet cover
    DSS Stage 2 axles front and rear
    Mods-Handling:
    Upgraded polyurethane motor mounts
    BulFab crossmember
    Ground Control coilovers
    RM Racing Front & Rear Sway bars
    3G rear control arms
    solid bushings for front/rear subframe and rear diff
    custom rear toe adjustable arms with spherical bearings
    RRE Front & Rear strut tower bars
    RRE lower tie bar
    Stainless steel braided brake lines
    Evo 8 brembo swap *required me to use +15mm jmf fab wheel spacers in the front to clear the calipers*
    3g Brake booster & MC upgrade
    Volk Racing TE-37 18x7.5 et41
    Rays Engineering Lug Nuts and Valve Seals and JDM center caps
    Yokohoma Advan S.4 225/40R-18
    Evo 9 Momo Steering wheel
    custom tubular rear subframe
    Background:
    I bought my car March 31, 2012 in Salem, VA
Share this Item
sorn likes this.
Comments
  1. sorn
    I would love that color on mine.
  2. iHavok
    bruh... beautiful
      mantega4g63 likes this.
  3. Michael Cusimano
    God those catch cans are dope!!!
  4. FoxEclipse
    That's a beautiful color! You've kept it nice and clean, too. Great job, man.
    1. mantega4g63
      yeah it's been down for 7 months :/ hoping to have it back in time for the shootout. awd, turbo, and motor swap taking longer than expected
      mantega4g63, Jul 16, 2015
  5. mattwiththeeclipse
    That's dope man! I have a 99 eclipse that I payed almost nothing for and is running stock other than a cold air intake. What would I have to do to get it completely tuned like you did? It is my end goal and will be my dream car when I am finished but idk where to even start.
    1. mantega4g63
      If it's a non turbo, I don't know enough about them to tell you anything. But for a turbo, you could reflash the ecu with EVO scan. First you need to figure out what power you want to make, then you need to find a trusted tuner and talk with him because you are limited by his tuning ability. I stuck with bolt-ons until I ran into idle issues with my bigger throttle body, and had to get it tuned
      mantega4g63, Oct 14, 2014
    2. mantega4g63
      Also I had to convert my non-eprom ecu to an eprom ecu which I had ECMLink do. I told you to go the evo scan route because you have a black box ecu since that came in the 99 turbo model eclipse. First pick an upgrade path (aka your desired hp level/range), then find a tuner and talk with him. I wouldn't let anyone talk you into using a SAFC, they work I just don't support shortcuts
  6. 95talongirl
    I love that color! Beautiful!
    1. mantega4g63
      thank you! no one believes it's a stock eclipse color
    2. mantega4g63
      I love that talon blue also, I was considering it. I've seen a bunch of rare talons with crazy blue colors, I couldn't find much info on them so I went with this eclipse blue
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
