- Ownership Status
- Currently Own
- Year
- 1999
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 20g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- td06sl2 20g, FP Exh Mani, Megan o2 housing, 3" exhaust, Fuel Lab regulator and plumbing. FIC 1120's, ETS racing FMIC, Tial QR, Xtreme PSI intake, Hallman MBC, new PS pump, alternator, gates h20 pump, new starter, New timing covers, MAP EGR blockoff, MAP clutch line, MAP Oil supply line. MAP braided stainless oil return kit. Mishimoto Aluminum Radiator/Spal Performance fans, K&N Filter, stock un-hacked 2g MAF
- Mods-Engine
- Scat race rods, polished crank, Wiseco HD1400 Forged Pistons, balanced,OEM BSE kit, New oil pump, .040 over-bore. ACL race rods/mains, ARP head studs, rod bolts, main studs, line bored, decked. Decked head, 4 angle valve cut, BC springs retainers, BC 272 cams, Ferrea valve seals,. MAP valves, Revised 3g lifters, new seals, powder coated valve cover, all new OEM timing components, gates Kevlar racing belt, 3g lifters,
- Mods-EMS & Logging
- Link v3, AEM wideband, Autometer Boos pressure, oil pressure. Autometer triple pod.
- Mods-Drivetrain
- stock trans, new u-joints, stock xfer case, LSD rear, solid driveshaft bushings,
- Mods-Handling
- stock suspension, 4 new rotors, new brake pads, Enkei RPF1 17x8 (black), Goodyear tires.
- Parts Wishlist
- SMIM, TRE/Jacks AWD 5spd trans.
- Background
- in 2003 I bought a used 99 GST in mint condition for $9000 from the local Mitsu dealer, and that car got me hooked. Im upgrading from a FWD TSi, to an AWD GSX, I have never driven an AWD car!!! probably wont have to running until this summer, but it's going to be fun putting it all together. I'm finally meeting other locals who are into 4g63 rides. Ive owned (9) _Starions_, with the g54b 2.6, khaltech EMS , Haltech AIC, etc... but AWD should be sick..
