Please Support Rix Racing
Road Race Build Budget 2g weekend time attack/ "barn find" restoration
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
50-trim
Drivetrain
AWD
Build Type
  1. Road Course
Pte5031e
External wastegate on slow boy exhanifold
Vrsf short route fmic
Hahn 3" turbo back/weird 3" o2 housing
Rewired Walbro 255
Fuel lab 818 filter SS element
6an filter feed to rail braided line
Fic low z 1650cc injectors
Aeromotive fpr and 6an lines to return hard line
4an turbo feed with restrictor
10 an braided turn oil drain
Heat wrapped downpipe and wastegate pipe
Fp 4" intake pipe
K&n air filter
Mods-Engine
Poly motor mounts
Fp2 cams
Fidanza adj. Cam gears
Diy C.o.p
Removed cruise control
Removed evap system
Removed ac system
Alm. Radiator and spal fans
Map Evo/dsm head studs
Cam and cas signal ran off 1g cas, flipped coil wires to not have to invert signal in ecmlink.
Kiggly hla regulator
Evo3 ofh and large external cooler
1g throttle body and ported intake inlet to match
Mods-EMS & Logging
Ecmlink v3
Innovate lc2
Gm 3bar map
Gmiat welded bung in the elbow 6" before tb
Glow shift tinted boost gauge (do not recommend)
Mods-Drivetrain
Act 2100 pp & 6puck sprung disk
Solid alm carrier bushings
Ss braided clutch line (master to slave)
Ksport coil overs
Ingals rear adj upper control arm mounts
Adjustable upper front ball joints
Old American racing TE reps.
Falken rt660's
Outlander bigger breaks
Abs delete with ss lines
Front poly sway bar and control arm bushings
Background
This car was bought by my brother in 2008 with a blown trans. Sat till I bought it in 2019. I am bringing it back to life.
Dyno HP
437 whp
417 lb/ft
Dyno Type
DynoJet
Dyno Video Link
Watch Video
Dyno Shop Name
Innovate auto market
Dyno Session Details
21 psi e85 stock 2g ign map 60deg 5500' elevation
97eclipsespyder
More in 2G DSM
Share this Vehicle
