1. Join the Community!
Street Build Brad's Zero G
Vehicle:
1988 Mitsubishi Starion
  • Ownership Status:
    I own it
    Turbo Type:
    14b
    Drivetrain:
    RWD
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    ACT streetlite flywheel, performance street clutch disc and pressure plate. Stock DSM intake manifold modified to swap the throttle body to the opposite side.
    Mods-Engine:
    6 bolt, Bored .02 over, Crank machined .01 over, BS removed, Oil passages bored over and cleared, Rods cleaned and machined .01 over, ACL Race bearings, ARP Head and Rod studs, Wiseco 8.5:1 forged pistons, 1G rods tested and balanced, 3 angle grind, new valve seats/slides, FP2X Cams, 1mm oversized Ferra race valves, Brian Crower titanium singles valve springs, MLS 5 layer head gasket
    Mods-Drivetrain:
    Starion KM132 transmission tail housing combined with Dodge d50 transmission.
    Parts Wishlist:
    Mishimoto Aluminum Radiator for 240SX, Zaklee Corp Clear Cam Gear Cover, TPP DSM Manifold Blanket, STM 2.5" Stainless Steel Throttle Body Elbow
    Background:
    I bought this car back in 2014 and essentially had no idea what I was getting myself into. Fast forward three years after going through tech school and becoming a full time technician I had blown the head gasket on the original motor and got a really good deal on a freshly rebuilt 4g63 from a friend who had given up on his 1G build. This time I really had no idea what I was getting myself into and ended up getting discouraged and abandoning the project. I've decided to pick it up again and give it another shot! I certainly don't need this car to be the fastest thing in the world, I honestly will be happy if I can ever get it to move again. I have plans to take a full 8-10 hour day once a month and make slow but steady progress on the swap, giving myself time to research, plan, and save up money.
Share this Item
Comments
  1. 4g64Starion
    Hey a fellow starquest! How's the build going?
      Brad4g63Starion likes this.
    1. Brad4g63Starion
      Hey, glad to see i'm not alone here! The build is going slowly right now but i'm trying to lay my base of planning and research to save myself time and money in the future!
      Brad4g63Starion, Apr 21, 2019
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned VR Speed Factory White Shed Speed
