- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 20g
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Road Course
- Mods-Bolt-on
- Injen cold air intake,10an oil catch can, 8an/6an fuel lines and adjustable fpr with walbro fuel pump and precision 680cc injectors, apexi neo safc, aem boost and eugo gauges. Customized coolant tube with 1/4npt bung(plugged) for sandwich cooler delete and 6an bung for turbo coolant hose, water outlet eoc return tapped to 1/4npt(plugged), mishimoto rad, external engine oil cooler, Chevy traverse power steering cooler modded to fit, fmic painted black with Eastwood rad paint.
- Mods-Engine
- 2.3 stroker, 4g64 100mm crank, acl coated bearings, balance shaft delete, Manley rods, wiseco pistons, Comp cams 101400, aem tru-time cam gears, gates racing timing belt, evo 3 ofh, supertech brass valve guides/double springs/titanium retainers, bc +1mm os valves, 3” turbo back exhaust built on my back lol.
- Mods-Handling
- Tien coil overs, thicker sway bars,
- Parts Wishlist
- Evo brake calipers.
- Background
- Work in progress. But plan to take to track days at msr houston in angleton Texas.
