bmoha2's Talon TSi AWD
- Year
- 1996
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Build Type
- Road Course
- Mods-Bolt-on
- Blitz supersound BOV, Blitz dual solenoid boost controller, Blitz 1.3 bar radiator cap, NGK 9mm plug wires, NGK one range cooler plugs, DNP SS exhaust manifold DEI wrapped, SS exhaust manifold studs and hardware, FP Big T28 turbo fully ported, SS exhaust manifold to turbo gasket, Variant SS atmospheric dump O2 sensor housing, Punishment racing 3 inch SS downpipe, no cat, 3 inch SS cat back Thermal Research exhaust, AEM adjustable cam gears, full set of Hahn Racecraft intercooler pipes, SS turbo oil feed line, battery relocated to the trunk, non cruise control throttle cable, cruise control eliminated, Variant non oiled air intake filter, Fluidyne radiator, Hahn racecraft SMIC, all verocious motor sports silicon 4 layer couplers, all verocious motorsports T bolt clamps!
- Mods-Engine
- Cometic headgasket, Buschur racing prepped head, extrude honed 2G intake manifold, HKS 264 cams
- Mods-EMS & Logging
- Blitz dual solenoid boost controller has digital boost gauge in bar, 2G socketed eprom ecu, Keydriver stage 3 chip! Keydriver chip dispalys points of knock in stock boost gauge!
- Mods-Drivetrain
- Jun cromoly flywheel, ACT 2100 clutch, Symborski shifter bushings, MachV underhood sealed cartridge bearing shifter bushings, B&M short throw shifter, SS braided clutch line
- Mods-Handling
- Ebc green kevlar brake pads front and rear, SS brake lines, Brembo slotted front rotors, Powerstop crossdrilled cadnium coated rear rotors, front and rear strut tower braces, H&R springs, Toikiko Illumina adjustable struts, strut top polyurethane bushings, Drag and winter wheelset; Enkei J10 16X7 wheels black with a silver lip, BFG traction T/A tires 225/50/16, Summer and autocross wheelset; OZ Superleggera 17X8 wheels silver wrapped in Falken Azenis 235/45/17s. Bulldog lugnuts
- Parts Wishlist
- carbon fiber hood, carbon fiber high turbo wing, carbon fiber hatch, Dsmlink
- 1/8 Mile E/T
- 10.865
- 1/8 Mile MPH
- 84.221
- 60' Time
- 2.000
