1991 Eagle Talon TSi AWD Vehicle Profile & Build Thread
blaster1812's Talon TSi AWD
Eagle Talon TSi AWD
Build Type
  1. Street
FP Race Cast Exhaust Manifold, Tubular O2 Housing (Atmosphere Dumped), EVO 16g, Punishment Racing 1G FMIC Kit, 1G 63mm Turbo TB With Half Shaft Mod, Walbro 255 lph Fuel Pump, FIC Injectors 850's, Fuelab AFPR
Mods-Engine
Ross Racing forged pistons
Eagle H-Beam Connecting Rods
Arp Main studs
Topline Oil Pump Assembly
Topline Waterpump
Topline complete gasket kit
Gates Timming belt
Felpro Mls headgakset
l19 Head studs
ACL Race Main Bearing set
ACL Race Rod Bearing set
Topline Revised Lifters
Supertech valves,guides,valve stem seals
3g lifters
Briancrower Springs/Retainers
BC 272 Cams
Mods-EMS & Logging
ECMLink V3Lite w/ socketed 91-94 EPROM ECU, AEM Digital Boost Gauge, AEM UEGO Wideband A/F Gauge, AEM Digital Oil Pressure Gauge, Speed Density
Mods-Drivetrain
RTM Underhood Shifter Bushing Kit, RTM Shifter Base Bushing Kit, Fidanza Lightweight Aluminum Flywheel, ACT 2600 Pressure Plate, ACT 6-puck Sprung Clutch Disk, 4 Bolt Rear End
K Sport Coilovers, Ingalls Adjustable Rear Upper Control Arms, RTM Rear Subframe Bushings, VMC Rear Active Toe Elimination Kit, 3000GT-VR4/Cobra Front Big Brake Upgrade Kit
1G DSM
blaster1812
Watchers
Comments
More in 1G DSM
Share this vehicle
