1990 Eagle Talon TSi AWD Vehicle Profile & Build Thread
blackjdm90's Talon TSi AWD
Eagle Talon TSi AWD
Shaved and painted valve cover, Custom 3" throttle body elbow,Wally 255 fuel pump, Aeromotive afpr with black stainless feed and return lines, CX t3to4e 60 trim turbo, custom bent and welded 9/16th 304 hard stainless return line and black -4 an stainless feed line, Turbonetics Evolution 38mm external wastegate with custom stainless dump tube. custom built t3 turbo mani (cut and welded myself), custom 32x12x3 front mount with 3 inch intake and 3 inch exit, with 2.5 inch hard piping cut and welded, Dejon hard intake pipe, k&n filter, Cyclone intake manifold, Slow Boy manual Boost controller, NGK bpr7es spark plugs, ngk wires, competition stage 4 clutch, custom built oil catch can, kevlar timing belt, 3 in turbo back exhaust cut out 1/3 of the way back.
Mods-Engine
JDM 6 bolt and tranny. Cyclone intake mani, stock internals so far
Mods-EMS & Logging
Keydiver stage 3 chip, socketed EPROM ecu, data logger, Apexi Safc2, Innovate LC-1 wideband, black face Prosport 30psi boost, voltage, oil pressure, oil temp and water temp gauges. 850 cc injectors tuned with Ethanol on my SAFC2
Mods-Drivetrain
OEM carrier bearing and axles for front and back, new OEM control arms front and back, new tie rods and bushings.
Drilled and slotted Baer rotors for front and back, ceramic high heat race pads all around, new rattle clips all around and powder coated calipers. welded in roll bar for my 5 point harnesses. from upper strut bar
Parts Wishlist
10 sec mods!
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Nitrous : No
Tires : Street Radials
Sponsored Car : no
0.0 lb/ft
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : Pump gas
