1. Join the Community!
Awdspyderman
Awdspyderman's Eclipse Spyder (AWD swap)
Year:
1999
  • Mods-Bolt-on:
    DEJON intake pipe, dejon hard upper and lower intercooler piping with 1g bov , 14b turbo, HX-35 going on after break-in period is over. Polished 14b compressor cover, polished TB elbow , stainless steel oil lines, when the hx-35 goes on i will also install a evo 8 front mount,
    Mods-Engine:
    2g 99' split thrust bearing motor bored .040 over and rebuilt with evo x piston's, 6 bolt rod's, stock crank repolished, new bearings, ARP hardware. The head will be rebuilt with stock valves, bronze valve guides, viton seals, EVO 8 valve springs and retainers, light port&polish, stock cam gears, stock camshafts(for now) 255lph fuel pump,fuel lab FPR, -6 an fuel lines, sstainless steel clutch lines,
    Mods-EMS & Logging:
    2g 99' flashable ECU, with ceddymods
    Mods-Drivetrain:
    shep stage 3 double synchro 3-4 gears, rebuilt transfer case, rebuilt driveshaft with oem parts, stock LSD rear
    Mods-Handling:
    tokico illuminas adj. ,eibach pro kit, goodridge brake lines, GSX big brake ( trying to uprade to brembo swap)polyureathne bushings were ever
    Parts Wishlist:
    t3 twinscroll exhuast manifold, galant legnum JDM knuckles, EDM folding 2g mirrors
  • 1/4 Mile E/T:
    0.000
    1/4 Mile MPH:
    0.000
    1/8 Mile E/T:
    0.000
    1/8 Mile MPH:
    0.000
    60' Time:
    0.000
    Dyno TQ:
    0.0 lb/ft
Share this Item
Comments
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
