- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse Spyder GST
- Turbo Type
- GT35 Variant
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- FIC 1680 High Z Injectors, rewired Walbro 450hp, 6an pump to rail, Fuel Lab 818 filter, Aeromotive FPR, stock feed as return, FP Exhaust Manifold, FP Intake Pipe, SlowBoyRacing Intercooler, HKS SSQV , Evo 3 Throttle body, Cyclone Intake , Gamble Garage 10AN Catch Can, Ingersol Rand Boost Control Solenoid, Dynatek Arc 2
- Mods-Engine
- Buschur Racing Stg 3 Head, GSC S2 Cams, Kiggly HLA, .5mm over stainless intake and exhaust valves
- Mods-EMS & Logging
- ECMLink V3, Innovate MTX-L WB02 & MTX-D Boost / Shift Light
- Mods-Drivetrain
- AWD Swapped, Solid Shifter Base Bushings & under hood shift bushings, Counterweight removed, Tubular Front Crossmember w/ Poly Bushing, Poly Trans, Engine & rear Engine Mounts, Stainless Clutch master to Slave Line,
- Mods-Handling
- 3G Brake Master Cylinder, Stainless Lines from BMC to Prop valve, Rear Brembos, Front GSX Calipers, Stainless Lines from hardlines to Calipers. Rx7 FD Rims
