andy4g63's Talon TSi AWD
- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- HOLSET HX-40,with a T3 flange in a 0.70 AR turbine housing from BEP,with a 3" v-band .
ERL cast stainless T3 exhaust manifold,custom 3" O2 eliminator DP with a VRS exhaust.TIAL 44mm WG,TIAL BOV.63mm,bored out NT TB form throttle bodys.com.JMF intake manifold,catch can and ovrflow bottle.Custom extremely short route,aluminum IC piping from ENZO racing.Optima red top battery/relocated/.RC 1000cc injectors,BPR7ES spark plugs,ACCEL wires.Wallbro 255-in tank,BOSCH 044 inline.1G fuel rail polished with 8AN fittings,Aeromotive FPR,Aeromotive fuel filter.EARL's 8AN fittings,back and forth Earl's -8 stainless fuel lines.EXTREME PSI intercooler 8x24x3.5.Perma-cool 12"-3000CFM rad.fan,10 slim fan in front of radiator.FLUIDYNE radiator,Mitsu OEM thermostat/180*,Greddy cap.
- Mods-Engine
- BLOCK:
JE 9:1 0.020 pistons,Eagle rods,ARP hardware everywhere,ACL bearings.Mitsu OEM polished and balanced crank,Mitsu MLS head gasket,ARP studs.BC 280 cams with a BC titanium springs and retainers,SI stainless 1mm oversized valves,3G lifters,Fidanza's adj. cam gears.
- Mods-EMS & Logging
- AEM EMS,AEM UEGO gauge,AEM serial gauge.EGT,water temp,boost,oil pressure,turbo timer by GREDDY.
- Mods-Drivetrain
- DOG BOX Race tranny,incl.new gears 1-4,new synchros everywhere,doble synchro on 2gear,all beaqrings,seals.4 spyder center diff,replaced input shaft,brand new OEM intermediate shaft,replaced also 5 gear.OEM axles,Symborski shifter base bushings,MachV shifter linkage bushings.Prothane motor mounts.ACT 2600 PP with a 6puck sprung hub disc,ACT chromemoly Streetlite flywheel.Stainless clutch line,new slave and master cylinder.Manual steering rack from a 1990 car.
- Mods-Handling
- KYB GR-2;EIBACH Pro-kit,adj.camber bolts
BRAKES:
2G front calipers with a BREMBO 2g slotted rotors,EBC Yellowstuff pads,Braided stanless steel lines.Rear Akebono ceramic pads,oem rotors,stainless lines.
- Parts Wishlist
- Beefier rods/CROWER,Howards/,HTA 88mm turbo from FP,paint job.
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Sponsored Car : no
- Dyno TQ
- 452.0 lb/ft
- Dyno Type
- DynoJet
- Dyno Shop Name
- Ivey Tune
- Dyno Session Details
- Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : Holset HX-40
