- Ownership Status
- Currently Own
- Year
- 1999
- Model/Trim
- Mitsubishi Eclipse GSX
- Drivetrain
- AWD
- Transmission Type
- Automatic
- Build Type
- Street
- Drag Race
- Showcar
- Mods-Bolt-on
- Tial 44mm wastegate, Tial blow off valve, VRSF front mount intercooler, Mishimoto 2 core radiator, 2 spall pusher fans, Walbro Hellcat 525 fuel pump, 8AN fuel lines, 2150cc FIC, Aeromotive fuel rail, Fuel lab regulator
RED DEMON Carbon fiber door
- Mods-Engine
- 92 6 bolt block(ported to clear rods), R &R aluminum long rods, Weisco 10:5:1 piston, L19 Arp studs, BSE, ACL Race bearings, Kiggly main girdle, Poly mounts, ATI Super Harmonic dampener, Evospec Performance Billet Underdriven water pump pulley, Jay's alternator relocation kit
CNC port and polished 2g(97) head, Kelford 272cams, AEM cam gears, Kiggly street dual valve springs, Titanium retainers, Ferra valves, Kiggly hla pressure regulator, 3g Lifters
- Mods-EMS & Logging
- Dsmlink v3, Speed Density, Innovative Lc-2 wideband, Ethonal sensor, Fuel pressure sensor
- Mods-Drivetrain
- JB design billet pan, JB standard ratio billet transfer gears, Kiggly 5 Friction pack, Translab shift kit, Welded diff, Morrison Fab shift brackets, Precision Industries torque convertor, Forced Four shift box, Frontline Fab Billet T-case brace, Frontline Fab Billet Rear diff cover/brace
- Mods-Handling
- KW Coilovers, Paul Volk front Lca's, Paul Volk solid K-member bushings, Megan Racing tubular adjustable upper control arms, Bullfab tubular crossmember Docol R8 tubing, Energy suspension bushings, Kirkey Pro street drag seat and cover
