Please Support Rix Racing
97 gsx awd
Ownership Status
No Longer Own
Mitsubishi Eclipse GSX
Turbo Type
GT42 Variant
Drivetrain
AWD
Build Type
  1. Drag Race
- Dual 450LPH pumps
- 2200 FIC’s injectors
- -8AN feed and return
- DWR2000 FPR
- Weldon fuel filter
- GM flex fuel sensor
- Tucked Koyo radiator
- Raven fab swirl pot
- Raven fab coolant pipe
- -16AN feed and return
- EvoSpec water pump pulley
Mods-Engine
- 6 bolt block 7 bolt head
- Forward facing oil filter housing
- Kiggly crank girdle
- Kiggly HLA
- Kiggly high pressure valve springs
- S90 throttle body
- JMF intake manifold
- Eagle max rods ARP 2000 bolts
- ARP main studs
- ARP head studs
- Cometic MLS head gasket
- Wiseco pistons
- Kelford 272/278 cams
- AEM cam gears
- ATI Super damper
- Rix racing timing marker
- ARP crank bolt
- ARP cam cap bolts
- ARP cam bolts
- ARP flywheel bolts
- Block bored 40 over
- Greddy timing belt
- Balance shaft delete
- Ported head
- ACL bearings
- Alternator relocation JaysRacing
- Dual -10 an valve cover
- Vibrant catch can -10an
- Stock valves
Mods-EMS & Logging
- AEM 5 bar MAP
- GM IAT sensor
- AEM 3 port boost controller
- 2GB cas
- 12 tooth trigger kit
- Fuel pressure sensor
- Oil pressure sensor
- Coolant pressure sensor
- Haltech 1000
- IC7 dash w mako dash holder
- WB1 wideband controller
- Ohm engine harness
- Smart coils x4
Mods-Drivetrain
- Shep stage 3 trans
- QuarterMaster 7.25 6 leg clutch
- Torque solutions drive shaft bushings
D2 coils
Tubular subframes
Parts Wishlist
None
Background
Bought this for my first dsm and wanted to go fast ended up growing up realizing I’ll never enjoy the car
blackbirdtalon
More in 2G DSM
Share this Vehicle
