- Ownership Status:
- I own it
- Turbo Type:
- GT35 Variant
- Transmission Type:
- Manual
- Build Type:
- Road Course
- Mods-Bolt-on:
- HX35 with BEP .55a/r Bolt-on Housing (by Justin)
FP Exhaust Manifold
Evo III Intake Manifold+60mm TB
TiAL38mm Wastegate
VRSF FMIC
Braided -6AN Fuel Feed
Aeromotive Mini AFPR
Walbro 450LPH
FIC 1450's
3" AMS Downpipe and HKS Exhaust (w/ 3" Cat)
FP intake w/ 4" K&N Filter
Aluminum radiator with Mishimoto shroud and single fan
All solid Prothane mounts
NGK BR7ES
Calan Catch Can w/ 2 -10AN inlets and 1 -12AN outlet
- Mods-Engine:
- 9.0:1 Comp
Evo 8 Valvetrain
HKS 264/272
B&M Oil Cooler
- Mods-EMS & Logging:
- ECMLink V3
Innovate MTX-L Wideband
Omni 4 Bar MAP
Devils Own Meth kit controlled with ECMLink with a DO5 nozzle
DREWJ Street Tuned
- Mods-Drivetrain:
- Centerforce Dual Friction Clutch
Fidanza Flywheel
Stainless Line from Master to Slave
Solid Bushings on Shifter Base and Cable Ends
- Mods-Handling:
- RMDSM Front and Rear Sway Bars
Tokico Illuminas/Tokico springs
3KGT VR4 4 Piston Front Calipers
Evo 8 2 Piston Rear Calipers
13.1" Front, 11.9" Rear
3G Booster + Master Cylinder
3G Tubular Upper Rear Control Arms
18"x8" Rota Torque
- Parts Wishlist:
- DG Koni Setup/FEAL Setup
Auto Swap
Join the Community!
Comments
Sort Comments By
