- Ownership Status:
- Currently Own
- Turbo Type:
- 16g
- Transmission Type:
- Manual
- Build Type:
- Drag Race
- Mods-Bolt-on:
- • Forced Performance 68HTA
• Forced Performance 4" intake
• Tial 50mm BOV
• Evo III Throttle Body
• Evo III IM ported by Curt Brown
• VRSF 26x10x3.5 front mount intercooler
• Fuel Injector Clinic 2150cc injectors and resistor delete plug
• Aeromotive Stealth 340 fuel pump
• Proclassic -6AN fuel hose (feed and return)
• Flex fuel sensor GM# 13577429 mounted on firewall
• Fuelab fuel filter (40 micron metal element)
• 1g fuel rail
• Fuelab adjustable fuel pressure regulator (43.5psi base fuel psi)
• Forced Performance race exhaust manifold
• Punishment Racing o2 housing (dumped to atmosphere)
• Tial 38mm wastegate (1.3 bar spring)
• Apexi GT 3" cat delete dp (DEI titanium wrapped)
• HKS hi-power catback exhaust
• ECMLink IR boost control solenoid
• Nology hotwires
• NGK BR8EIX spark plugs gapped to 0.025"
• Zaklee clear cam gear cover
• Prothane side motor mounts
• Adam Porto solid front/rear roll stops
• AFCO 80107N race radiator
• -16AN Earl's radiator hoses
• 143* Mishimoto thermostat
• single 12" push fan
• Genesis 16EP small battery (13.8lbs) relocated to subframe with JMFab tie down
• Calan VS2 catch can 10AN inlet and 8AN outlet
• Vamos Fab 4" front drive shaft loop
• CNC 412 staging brake (plumbed to lock-up front right & back left) with fabricated hardlines
• Gofer Aero 100% carbon fiber bumper shutters
• TPP black exhaust manifold blanket
• Jay Racing alternator relocation (steel)
• Frontline Fabrication spare tire delete
• EDM tail lights
- Mods-Engine:
- • Arizona E-54
• Forced Performance FP2 cams
• Brian Crower adjustable cam gears (I/E both set to 0)
• Kiggly HP beehive valve springs (97lbs at 1.440")
• OE Evo rockers
• engnbldr SS valves
• engnbldr bronze valve guides
• Topline revised lifters
• standard ARP head studs (tq to 90ft lbs)
• OEM Mitsu composite headgasket (copper sprayed)
• Fluidampr harmonic damper crank pulley
• stock 7-bolt bottom end with 100k+ and balance shafts
- Mods-EMS & Logging:
- • ECMlink (V3) Speed Density
• Innovate MTX-L wideband (rear o2 location)
• AEM Digital (50psi) boost gauge
• AEM X-Series (100psi) oil pressure gauge
• AEM X-Series (100psi) fuel pressure gauge
• AEM 5 bar MAP sensor (boost)
• AutoMeter 2246 0-100psi (turbo back psi) @ EGR port
• AEM 2 bar MAP (crankcase psi)
• GM IAT on UICP
- Mods-Drivetrain:
- • AWD GS-T conversion
• automatic converted to 5 speed manual
• ShepTrans stage 4 w/ 4 spider CD, LSD, Evo 1st, 3rd, 4th gear and REM ISF
• ACT Twin Disk
• Frontline Fabrication girdled steel rear diff cover
• Jeff Bush t-case brace
• Evo shift knob
• B&M short shifter
• Symborski shift kit
• Mach V shift cable bearings
• Shep trans solid shifter cable bushings
• ExtremePSI SS full clutch line
- Mods-Handling:
- • Paul Volk (99gst_racer) chromoly tubular rear subframe, LCA's, and toe arms
• EMW depowered (Miata mod) 2g steering rack
• Evo rear Brembos
• Stock AWD DSM front calipers
• RotorPros CD/S rotors
• Hawk HPS pads
• 2003 Eclipse 8+9 brake booster and 17/16" master cylinder
• SS brake lines
• Dennis Grant Koni coil overs
• Hypercoil springs (750fr / 350r)
• Evo steering wheel
• 2slow4now's Evo to DSM steering wheel adapter hub
• Sparco Evo 2 seat
• RMDSM sway bar (rear) OE front
• DC sport rear strut tower brace
• ARP extended wheel studs
• Evo IX Enkeis 17x8 +38 wrapped with 245/45/17 Bridgestone Potenza RE760's
• Evo IX Enkeis 17x8 +38 wrapped with 245/45/17 Hoosier DR's for the track @ 22psi
• Enkei RPF1s 17x9 +35
- Parts Wishlist:
- • 8-point roll cage
- Background:
- 11.49's or bust!
Join the Community!
Share this Item
Justin DuBois, Wil_EclipsePH, AZ95GS-T and 11 others like this.
Comments
Sort Comments By
