- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- JM Fabrications DRAG Intake Manifold w/ nitrous ports, Accufab 75mm Throttle Body, Tial Q BOV, Spearco 2-216 FMIC (3" coldside/ 2.5" hotside), GT40R Turbocharger (Jet-Hot coated turbiine housing), Shearer Fab TopMount T4 Exhaust Manifold (Jet-Hot Coated), TWO Tial 44mm Wastegate, JayRacing alternator relocation kit, BJ's Fuel Rail, PTE 1600cc Injectors, Fluidyne Aluminum Radiator w/ -16AN steel-braided upper hose, FAL Fans, Flex-A-Lite Power Steering/Oil Cooler, Custom 3" SS V-Band Mandrel Downpipe, APEX'i GT-Spec Catback Exhaust.
- Mods-EMS & Logging
- Autoronic PnP Standalone ECU, Autronic 500R Ignition amplifier, Hayabusa Coils, Innovate Gauge Type Wideband, AUTOMETER Voltage, Fuel Level, Oil Pressure, Boost and Water Temp Gauges.
- Mods-Drivetrain
- PTT Twin Disc Clutch Kit with cintered discs, Custom TRE Stage3 Trans, SpeedDesign 4spider diff w/ Torrington Bearing upgrade), THREEspeed Scattershield, solid shifter bushing kits (shifter plate & underhood trans), Wilwood 12.2" 4-piston calipers (front), RRE Slotted Rear Rotors (vented rear), Hawk HPS Pads.
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
- Dyno Type
- Dyno Dynamics
- Dyno Shop Name
- ATX Motorsports, NJ
- Dyno Session Details
- Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : Full Garrett
Boost : 22
