- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 20g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- fic 950 injectors, walbro 255 fuel pump, mhi 20g turbo, ported 2g exhaust manifold and turbo housing, punishment racing recirculated o2 housing, tial 38mm external wastgate, 3 inch thermal exhaust, dejon tool intake, fmic, mishimoto radiator, ngr bov, external air cooled oil cooler, calan catch can setup, 1g green top cas, ngk spark plug wires, evo 3 intake, 1g throttle body, Devils own water meth kit with progressive controller
- Mods-Engine
- 6 bolt bottom end, wiesco 8.3:1 2g pistons, 6 bolt rods with arp bolts, acl race series rod and main bearings, oem oil pump, bsd kit, stock crank uncut, stock 2g head rebuilt with evo 8 valves, springs and retainers, cometic mls head gasket, arp head and main studs, oil port mod 1 done, 90 ofh with relief valve ported, delta hks 272 cams,
- Mods-EMS & Logging
- ecmlink v3 full, speed density, lc1 wideband, auto meter oil pressure gauge, glow shift boost gauge, afpr, fuel pump rewire
- Mods-Drivetrain
- awd swap, evo 1 gearset, 4 spider center diff, evo shift rails and forks, poly motor mounts, poly roll stops, boston performance rear diff mounts, comp clutch flywheel, sbc ssx pressure plate, sbc Kevlar disc
- Mods-Handling
- stock for now
- Parts Wishlist
- clean shell to start over with
- Background
- Pulled it out of a pasture in the middle of the winter, evicted the mice and been building it ever since.
