1993 Eagle Talon TSi AWD Vehicle Profile & Build Thread
92DSMErdrick's Talon TSi AWD
Eagle Talon TSi AWD
Bullseye 47-Trim stage 4 wheel, SLS 02 Housing, Tial 38mm Wastegate, EVOIII Ported Exhaust Manifold, ACT 2600, ACT Flywheel, RC 1000cc Injectors, PE Timing belt, JMF Intake Manifold, SS lines to FPR and BOV, Aeromotive FPR, GM Maf + Translator, 3" Turbo back exhaust, SS oil feed/drain, Solid Clutch Line, HKS SSQV BOV V2, BOSCH 040 intank Fuel Pump, -8AN SS Fuel feed, FMIC (bottom of the bumper to the bottom of the headlights) Custom 2.5" IC piping, Bored N/T Throttle body to 63mm, UH Shifter Bushings, Symborski Shifter Base bushings
-E85 Fuel
Mods-Engine
MLS Head Gasket, Mildly Ported/Polished Cylinder Head, 3g revised lifters, BC Springs/Retainers, SS Nitrated Valves, BC 272's, Bronze Intake Guides, Iron Exhaust Guides, Wiseco 9.0:1 pistons, Manley Rods, BS Removed, ARP Head/Main/Rods
Mods-EMS & Logging
DSMLink, PLX WB, Greddy Boost and EGT gauge, AEM 5 Bar, Autometer oil pressure Gauge, Glowshift Fuel pressure LED Gauge
Mods-Drivetrain
Stock rebuilt Transmision with Posi diff, Steel Shift forks, 4-bolt Rear end Conversion
Prothane Motor mount inserts, KYB-AGX's, 3000gt rotors and Dual Piston Calipers, SS brake lines, Cross drilled rotors
Parts Wishlist
Better Suspension setup, New tires/rims, Bigger turbo, paint job
1/8 Mile E/T
9.574
1/8 Mile MPH
80.560
Timeslip Video Link
Watch Video
Timeslip Photo Link
Timeslip Details
Track Name : Old Bride Raceway Park
Fuel Used : Pump gas
Tires : Street Radials
Sponsored Car : no
1.0 lb/ft
Dyno Type
Dyno Dynamics
Dyno Sheet Photo Link
Dyno Video Link
Watch Video
Dyno Shop Name
RIPP Modifications, NJ
Dyno Session Details
Nitrous : No Nitrous
Turbo : 14b
Boost : 21
