- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 20g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Autocross
- Mods-Bolt-on
- Fmic, aftermarket adjustable fpr, 3 inch Gm mas / translator, 3 inch custom 02 housing, hks external waste gate, Turboxs bov, walboro 255 fp, 750cc injectors, custom built 3 inch exhaust from o2 back, 18g w/ 7cm exhaust wheel, innovative wbo2 , manual boost controller, 70a polyurethane motor mounts
- Mods-Engine
- Balance shafts eliminated, evo3 intake cam, hks 272 exhaust cam, 2g ported exhaust manifold , 2g lifters ( if memory serves. Its been a while)
- Mods-EMS & Logging
- Eprom ecu, ostrich chip emulator, apexi safc, gm maf translator.
Gauges... Autometer a/f, egt, voltage, oil temp, water temp, 2 boost gauges ( 1 intended to read pressure at fmic. ) palm pilot emulator on laptop for separate data logs. Hks turbo timer
- Mods-Drivetrain
- Centerforce dual friction clutch, stainless braided clutch line
- Mods-Handling
- 2g front rotors and calipers, ruff racing 17 inch rims, toyo tires 215/55/17
- Parts Wishlist
- Dsmlink v3, tubular upper rear control arms, rear tow eliminator, cobra rotors and calipers, braided fuel and brake lines, fuel pump rewire, tubular exhaust manifold, adjustable struts, magnus intake, speed density setup, higher lift cams 272s or higher, wiesco pistons and better then stock rods. Are hardware. Aluminum radiator, external oil cooler, 3g brakes master and booster.
- Background
- This 92 was my first awd I attained in a trade for a 93 Talon NT 1.8l that was identical to the awd. The seller was looking for a daily driver and accepted the offer immediately after seeing the pictures of my 93. He had bent all 8 exhaust valves and couldn't do the repairs needed. I have had atleast a dozen dsms but this 92 is by far my favorite. Piad for allot of my parts porting manifolds and turbos. Rebuilding turbos and powder coat work.
Main goal is to set the car up for autocross/ Street car and continue to drive this car for years to come. Many years working in a full service shop , alignments, suspension, engines brakes ect this job is going to be a little more difficult due to fabrication and design. Paint will be unique hopefully but still blackberry affect with bit of red metallic. Hope looks black at night but in daylight subtle red accent. Also grew up with best whos dad had a body shop. And had schooling in autobody.
