75 F350 4x4
Ownership Status
Currently Own
Vehicle
1975 F350 4x4
Drivetrain
AWD
Build Type
  1. Street
Holley 1050 3 barrel with annual boosters. Maddog 2" primary to 3.5" collector headers. Pan evac system.
Mods-Engine
521 stroker - D9 460 block .030 over w/ forged 4.3 stroke Scat crank. Eagle 6.8 Forged H beam rods, Lunatic solid flat cam - Advertised Duration (Int/Exh): 276/286 ;Duration @ .050 (Int/Exh): 247/256 ;Gross Valve Lift (Int/Exh): .630/.637 ;LSA/ICL: 106/100 ;RPM Range: 3500-6800. HV oil pump w/ 1" od pick up. 9qt deep sump pan.
AFR 295 heads w/ AFR 4150 single plane intake
Mods-EMS & Logging
Full custom made gauge cluster. Autometer - Oil pressure, oil temp, water temp, vacuum, speedo. Stewart Warner tach. Yamaha fuel management system. Lc2 Afr.
Mods-Drivetrain
Close ratio Zf-5 5 speed (idi), McLeod twin disc. Divorced and twin sticked 203/205 doubler. Dana 60 front w/ 4.88s, Detroit, 35spl chromos, Yukon hubs, Reid knuckles. 14 bolt rear with 4.88s, Detroit, UFC truss. 1410 joints all around.
Full crossover power steering w/ 2wd box and hydro assist. Hydro boost brakes with 4 wheel disc. 14b has sterling 10.5 brake setup. Icon 6.5 springs up front, stock Chevy 56s out back with shackle flip and 6" ORD super shackles. Custom hangers and crossmembers. DOM Anti wrap bar.
Currently on 40s, has also been on 38s and 42s
Videos
Adam
More in Misc Vehicles
Share this Vehicle
