1. Join the Community!
Street Build 420A little hobby Project build lol
Year:
1996
Model/Trim:
Eagle Talon N/T
  • Ownership Status:
    Currently Own
    Drivetrain:
    FWD
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    Have to get my list together never had a list
    Went with all gates parts for water pump and timing/pulleys along with gates Hydraulic tension.
    Exhaust Headers
    Fuel pressure regulator
    Rev limiter
    Trans swap
    Cold air intake "done right"
    Master clutch Cylinder
    Removed power steering pump AC and heater core parts and there fuses to them.
    And more I cant remember right off hand
    Mods-Engine:
    Gasket matching smoothbore with Port and Polish stage 3 on both Exhaust and intake side, Nascar built clutch kit, replaced all gaskets and seals, rebuilt top end...
    Mods-EMS & Logging:
    Vacuum gauge
    Oil Pressure gauge
    Temp gauge
    Will be installing more soon.
    Mods-Drivetrain:
    New axles
    New transmission I have a 2nd trans I'm actually working on changing out my gear ratio alongside other parts in the back up trans.
    Mods-Handling:
    All new aftermarket Suspension set up front and back along with
    Aftermarket Traction control/sway bar's front and rear for the top and the bottom
    17in wheels
    Wilwood Calipers
    Bigger brake rotors Slots an ported
    Spoiler
    Parts Wishlist:
    To many to think of at this moment lol.
    I'll get back to yall on this one.
    Background:
    It sat for a couple years after the owner didn't have the cash to fix it then finally they put $900 on it sat for 6 more months then I offered them $420 cash for it not even knowing it had the 420A block in it lol smh. They said all it needed was a clutch kit well it had a broken motor mount leaking exhaust headers bad and alot more so after having to pull motor I said the hell with it and started my new Project build lol.
Share this Item
Comments
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
