- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Eagle Talon TSi
- Turbo Type
- 20g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- ETS Full Race FMIC/ ultra short route , HKS SSQV Bov, FP intake, Vibrant MAF adapter with K&N Filter, FP manifold w/ mani blanket, FP Green HTA, Zanklee Clear Cam Cover, Powdercoated Valve Cover, NGK Spark Plug Wires & Bpr7es plugs, Aeromotive Fuel Rail & AFPR, Injector Dynamics 1000cc, Walboro 255 with rewrite kit, Optima Red Top Battery, Prothane Engine Mounts, Spal Electric Fan, Punishment Racing o2 housing w/Tial wastegate, Megan Racing DP cat delete, Thermal cat back exhaust, STM Chrome Power Steering Reservoir, Cruise Control Delete, 100% Full Black Interior Swap including Silver Face Gauges, Greddy Radiator Cap, New OEM Hood Insulator, 4300k HID's
- Mods-Engine
- 2.2 Stroker
98 revised 7 bolt block, Eagle crankshaft, Eagle 2g rods, CP forged piston 156mm, ACL race main bearing, / rod bearing / thrust bearing, GSC race balance shaft delete, ARP main studs & head studs, Cometic head gasket, SuperTech intake& exhaust valves / and valve guides, FP2 cams, Gates blue timing belt
New oem
Timing tensioner
Timing Idler
Water pump
All new gaskets
Mitsu front cover
- Mods-EMS & Logging
- 3pillar gauges(boost,temp,air fuel)
eprom ecu, Innovate lc-1 wb (red gauge), dsmlink v3 lite w/ socket service on ecu
- Mods-Drivetrain
- B&M short throw, symborski shift kit, ACT 2100 clutch kit w/ Fidenza flywheel (7bolt), Extreme PSI SS clutch line (Slave to Master Cyl)
New OEM pivot ball, release clip, release fork, throwout bearing, Machv (oem) heavy leather shift knob, Machv precision bearing shifter cable bushing kit
- Mods-Handling
- tokico 5 way illuminas, eibach pro-kit springs, No-name Top front/back tower strut bar, EBC green stuff brake pads, Enkei RPF1 17x9 +35 wrapped in 245/45/17
Uninstalled
GSX Duel Piston Brakes All Round
StopTech Slotted Rotors
- Parts Wishlist
- AWD Swap
- 1/4 Mile E/T
- 14
- 1/4 Mile MPH
- 100
- 1/8 Mile E/T
- 8
- 1/8 Mile MPH
- 80
- 60' Time
- 2.033
- Timeslip Details
- Nitrous : No
Fuel Used : Pump gas
Tires : Street Radials
Sponsored Car : no
- Dyno HP
- 210 whp
- Dyno TQ
- 210 lb/ft
- Dyno Type
- DynoJet
- Dyno Session Details
- Nitrous : No Nitrous
Turbo : 20G
