- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- AEM Tru-Time Cam Gears
JM Fab "Race Version" Billet Sheetmetal Intake Manifold
S90 Billet 74mm Throttle Body
FP Cast Iron Exhaust Manifold Ported
FIC 1800CC Low-Z Injectors
Fuel Lab 818 Fuel Feed Upgrade Kit
Fuel Lab 515 Fuel Pressure Regulator
Evo III 16G
Turbo Smart non Adjustable BOV
- Mods-Engine
- 6 Bolt Block, 2g Head,
Wiseco Forged Pistons 9.0:1,
Eagle Rods
K/N Cold Air Intake,
Kelford 272/272 R Cams,
Ferrea 6000 Series Exhaust and Intake Valves
Kiggly Racing HLA Pressure Regulator,
Kiggly Racing "High Pressure" Beehive Valve Spring and Titanium Retainer Set,
HKS Fine Tune Timing Belt
- Mods-EMS & Logging
- ECM Link V3
- Mods-Drivetrain
- ACT (2900) MaXX Xtreme Street Clutch w/ OEM Release Bearing
Fadanza Lightweight Aluminum Flywheel
Stock Trans Aside from Torrington Bearings on Center Diff
- Mods-Handling
- Drilled and Slotted Rotors with Ceramic Brake Pads
- Parts Wishlist
- FP Zero BB bolt on Turbo With External Wastegate Setup
- Background
- Have Speed Density set on the car, Just messing around with DSMlink. Currently Estimated 420hp (Maybe more) street tune on E85, Estimated 380Hp on 92 Pump Gas. (Per ECM Link)
