- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 20g
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- mishimoto radiator
godspeed coilovers
greddy 2.5in turbo back exhaust
turbosmart dual port blow off valve
02dump
20g turbo
cxracing front mount intercooler
1000cc injectors FIC
low profile high performance mishimoto fans.
AEM fuel pressure regulator
ARP head studs
Oil catch can
innovative wideband
255 walboro
- Mods-Engine
- stock internals just ARP head studs
- Mods-EMS & Logging
- ecm link v3 on a window tablet mounted in my car.
- Mods-Drivetrain
- stage 2 clutch
- Mods-Handling
- god speed coilovers with a 2 inch lower on 17x8.5 wheels +30 offset + 2in wheel spacers andd sway bars.
- Parts Wishlist
- the MAperformance stage 1 cylinder head preperation
Kelford cams
MAP 2.3 stroker stage 2 setup
- Background
- bought off a buddy who didnt have time or money to invest in it since its a rust free body solid motor and trans. i ended up dropping over 5grand to get all the maitence and everything done plus added some mods. eprom ecu . gonna tune and hopefully reach my goal of 400hp and make it show worthy with the cosmetic's ive done to it as well. unfortunatley the timing was messed up on it bent a valve currently rebuilding the motor better and stronger than ever. thankfully was only cylinder head damaged. no metal flakes in oil pan. re doing all the idler tensioner and everything else for the timing along with new water pump. beefing up the head while its out. by the time summer starts she will be road ready.
