1. Join the Community!
Street Build 2g eclipse dsm
Year:
1998
Model/Trim:
Mitsubishi Eclipse GST
  • Ownership Status:
    I own it
    Turbo Type:
    16g
    Drivetrain:
    FWD
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    Evo3 16g, tubular manifold, evo3 02 housing, hks cat back exhaust, hks ssqv, vsfr front mount, injen intake pipe, Ingersoll rand bcs, Fuellab fpr, walbrp 255 fuel pump,
    prosport gauges (boost, oil pressure, water temperature) ngk plugs and wires
    (pte 1000cc injectors not currently installed)
    Mods-Engine:
    Rebuilt motor, arp studs, Ross pistons, eagle rods, hks timing belt, balance shafts removed, BC 272/272 cams with fidanza adjustable cam gears, si dual springs w/ Manley titanium retainers
    Mods-EMS & Logging:
    Ecmlink V3 Full, Innovate LC-2 WB
    Mods-Drivetrain:
    Rebuilt trans from jacks transmissions, ACT 2100 clutch ACT fly wheel, short shifter
    Parts Wishlist:
    3” exhaust, egt gauge,
    Background:
    I’ve owned the car for 15 years, getting back into working on it trying to work out drivability issues/ check engine. I kind of worked on the car the backwards compared to others. Work on the motor before bolt ons still around stock boost till I get all the supporting mods and ecmlink. Painting the car and new rims are last on the list even though it really needs it
Share this Item
Comments
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
