- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GST
- Transmission Type
- Automatic
- Mods-Bolt-on
- Godspeed fmic. Greddy type RS BOV. Venom SMIM with BBK throttle body. 3 inch turbo back exhaust. Walbro 255 hard wired fuel pump.
- Mods-Engine
- 1994 Galant 4g64 Dohc block machined flat, 87mm Wiseco HD pistons, ACL main and rod bearings, 7 bolt milled head with Venom Smim, Brian Crower 280 camshafts, Brain Crower valve springs, Cometic Mls headgasket, Arp head studs, PTE 1000cc injectors, afpr, Custom tubular T3 manifold with Tial 38mm wastegate, Holset HX35 turbo
- Mods-EMS & Logging
- H8 ecu tuned by Stacey at My1gdsm.
- Mods-Drivetrain
- Automatic transmission with shift kit, and 3700 Stall converter with lock up still installed, Kiggly 7-Bolt SFI rated flexplate.
- Mods-Handling
- Drilled and slotted rotors front and rear. GSX (2 piston) calipers
- Parts Wishlist
- Fast, Fast, Fast
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
