MJcanada's Eclipse GST
Ownership Status
No Longer Own
Mitsubishi Eclipse GST
Turbo Type
16g
Drivetrain
FWD
Build Type
  1. Road Course
Walbro 255lph rewired, Full 3" eBay tial v-band converted ss exhaust-no axle back, chop top AFPR, SBR short route intercooler. Emissions delete, A/C Delete, no cruise control.
Power Enterprise Super Kevlar II Timing belt. Top line B-belt. Oem harmonic balancer. Aluminum PS pulley. Aluminum alternator pulley, 110 amp alternator.
SS clutch slave cylinder line. clutch fluid accumulator deleted.
Evo 8 MR 10.5T turbo with custom manifold, v-band custom o2 housing, and ss oil feed line from ofh with restrictor(drilled out) on turbo. Greddy type RS.
Mods-Engine
.40 cylinder bore. ARP head studs. Skunk2 evo8 272/264 cams. Topline ceramic coated pistons. Modified 2g cam trigger plate. Revised lifters.
Mods-EMS & Logging
Equiss manual boost gauge. link v3lite-mitsu style sd kit. In-cabin boost controller-hallman mbc. innovate LC-1 with G2 gauge
Mods-Drivetrain
Act 2600 PP. Stock flywheel. ACT 6 puck unsprung. skateboard bearing shift cable mod. Solid aluminum shifter base bushings and shifter sleeve.
DG/koni Coil overs. front upper control arm sliding ball joints. 2 piece Volk Ag rims 17x8+35. power slot 1g awd front rotors and hawk hp+ pads. 95 rear big brakes. Ingalls rear camber kit.
Parts Wishlist
GSC S2 cams, wesieco pistons, I beam forged rods, arp bottom end fastners. Another set of tsw vx1's.
1/8 Mile E/T
9.016
1/8 Mile MPH
85.830
Timeslip Details
Track Name : Greer Dragway
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 2970
Tires : Street Radials
Sponsored Car : no
255.8 lb/ft
Diamond Star Werks
More in 2G DSM
More from Diamond Star Werks
Share this Vehicle
