- Year
- 1999
- Mods-Bolt-on
- DEJON intake pipe, dejon hard upper and lower intercooler piping with 1g bov , 14b turbo, HX-35 going on after break-in period is over. Polished 14b compressor cover, polished TB elbow , stainless steel oil lines, when the hx-35 goes on i will also install a evo 8 front mount,
- Mods-Engine
- 2g 99' split thrust bearing motor bored .040 over and rebuilt with evo x piston's, 6 bolt rod's, stock crank repolished, new bearings, ARP hardware. The head will be rebuilt with stock valves, bronze valve guides, viton seals, EVO 8 valve springs and retainers, light port&polish, stock cam gears, stock camshafts(for now) 255lph fuel pump,fuel lab FPR, -6 an fuel lines, sstainless steel clutch lines,
- Mods-EMS & Logging
- 2g 99' flashable ECU, with ceddymods
- Mods-Drivetrain
- shep stage 3 double synchro 3-4 gears, rebuilt transfer case, rebuilt driveshaft with oem parts, stock LSD rear
- Mods-Handling
- tokico illuminas adj. ,eibach pro kit, goodridge brake lines, GSX big brake ( trying to uprade to brembo swap)polyureathne bushings were ever
- Parts Wishlist
- t3 twinscroll exhuast manifold, galant legnum JDM knuckles, EDM folding 2g mirrors
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
