- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- Mitsubishi fp green size turbo on 7cm ported housing 3" Thermal Exhaust, 38mm tial wastegate, PR external 02 hosing, FIC Hi-z 1680cc injectors,FP intake and K&N 9" filter, fp exhaust manifold, EVO3 intake manifold,vrsf short route intercooler, 1g throttle body, hallman boostcontroller
saturn alternator, 340lph fuel pump rewired, Tial Q bov. Fuel lap fuel pressure regulator, NGK wires and spark plugs,aluminum radiator, Red top Optima Battery, 1g oil cooler with -8an lines.
- Mods-Engine
- Build 6 bolt bottom end with balance shaft deleted. ACL race bearings. JE "frs" 2g pistons with 1g eagle rods 7bolt head with 3 angle valve job.evo valve springs and retainers and Kelford 272 cams and ferrea valvestem seals
- Mods-EMS & Logging
- dsmlink v3 on Speed Density and running e85
- Mods-Drivetrain
- Competition Stage 3 Clutch
- Mods-Handling
- Koni w/ground control coilovers
225/50r16 FD Rx7 rims
rear strut bar and front and rear camber kit.
- 1/4 Mile E/T
- 12.400
- 1/4 Mile MPH
- 115.000
- 1/8 Mile E/T
- 8.000
- 1/8 Mile MPH
- 90.000
- 60' Time
- 1.900
- Timeslip Details
- Track Name : Texas Motorplex, Ennis TX
Nitrous : No
Fuel Used : E85
Vehicle Weight : 3150
Tires : Street Radials
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
- Dyno Session Details
- Nitrous : No Nitrous
