- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Build Type
- Drag Race
- Mods-Bolt-on
- Gates water pump, gates timing belt, all brand new oem timing components, Aem tru time cam gears, ETS shortest route FMIC, all three harnesses proffesionally stripped, cleaned and tucked and wired for an evo 8 ecu.
- Mods-Engine
- 2.3L stroker. Manley platinum stroker pistons, Manley turbo tuff rods, 100mm crank, OEM balance shaft elimination kit.
SIM built "stage" 2 head, kelford 272 cams.
- Mods-EMS & Logging
- Evo 8 ecu , Defi boost, oil pressure and water temp guages.
- Mods-Drivetrain
- Tmz performance "stage" 3 transmission.
- Mods-Handling
- Tubular rear subframe built by Paul Volk, Dennis Grant spec Koni adjustable coil overs, Evo 8 brembo front and rear calipers powder coated pearl white, galant knuckles.
- Parts Wishlist
- Frontline Fabrication spare tire block off plate.
- 1/4 Mile E/T
- 12.275
- 1/4 Mile MPH
- 111.950
- 1/8 Mile E/T
- 7.920
- 1/8 Mile MPH
- 89.820
- 60' Time
- 1.695
- Dyno TQ
- 312.8 lb/ft
- Dyno Session Details
- Nitrous : No Nitrous
