Dsm2Nv's Spyder Gsx
Ownership Status
Currently Own
Mitsubishi Eclipse Spyder GST
Turbo Type
GT42 Variant
Drivetrain
AWD
Build Type
  1. Street
  2. Drag Race
Bosch 044
WALBRO 450 LPH FUEL PUMP
-10an fuel feed
-8an fuel return
FIC 2150cc
Magnus AFPR
Magnus Fuel Rail
Magnus Cast Manifold
Fuel lab 75 micron SS fuel filter
Earl's 75 micron pre pump filter's
Borg Warner s472
Sheepey Top Mount with hot parts kit
4" downpipe
Tial Q
AFCO radiator
NGK copper BR9ES plugs
Spark Tech COP
Dynatek ARC-2
ETS 5" super short route FMIC
Mods-Engine
Block
Powder Coated Block
Manley Pistons (HD Pins)
Manley I-Beam Turbo Tuff Rods
Eagle Crankshaft
Kiggly Girdle
Arp Main Bolt
Acl Race Bearings
Arp Crank Bolt
Head
Magnus Stage 3 Head
Revised Lifters
Hks 272 Cams
Aem Cam Gears
Kiggly Oil Pressure Regulator
Arp Stainless Manifold Studs
Accessories
Oem Front Oil Pump/cover
Hks Head Gasket
Arp l19
Oem Water Pump w/ Straight cut gears
Oem Timing Components
Mods-EMS & Logging
ECMLink V3 AEM wideband,Aem oil pressure, Aem boost Gauge 50 psi
Mods-Drivetrain
AWD Swap
Evo Rear Diff
5spd
DSS 3.5" driveshaft
Solid rear subframe and diff bushings
Street light Flywheel
Welded Center Diff
ss-x pp w/ Full-Face Ceramic Disk
Koni Shocks and Springs
Front sturt bar
Wilwood 4 piston fronts
SS brake lines
Odyssey PC680 battery in trunk
Parts Wishlist
Paint, Carbon Hood, Carbon Trunk, Enkei Rpf1 sbc, Slicks
1/8 Mile E/T
00.000
1/8 Mile MPH
00.000
Timeslip Details
Track Name : Cayuga
Nitrous : No
Fuel Used : Pump gas
Tires : Street Radials
Sponsored Car : no
Dyno HP
000.0 whp
000.0 lb/ft
Dyno Type
DynoJet
Videos
my car
short video of my car
Dsm2Nv
More in 2G DSM
Share this Vehicle
