95eclipseSlow's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
GT35 Variant
Automatic
Build Type
  1. Drag Race
Kelford 280/276, AEM adjustable cam gears, Magnus v3 cast intake manifold w/ nitrous bungs, s90 74mm throttle body, JMF v-band exhaust manifold, Avid 90a motor mounts, Magnus fuel rail, ID2000 injectors, FP3794r with Tial 1.03 housing, Saturn alternator, Aeromotive pro series fuel pump, Aeromotive A1000 for, Frontline Fab bolt in fuel cell, aeromotive fuel pump controller, TR1245 intercooler, 3.5" bumper exit exhaust, tial 44mm mvr, tial q bov
Mods-Engine
Fully built Boostin Performance 6 bolt short block, L19 head studs, Curt Brown spec head, Kiggly hla, Kiggly main girdle
Mods-EMS & Logging
AEM EMS series 1, Kiggly 12 tooth crank trigger, green top CAS, 24 tooth CAS trigger disc, Dynatek Arc-2, Buschur COP, AEM uego wideband
Mods-Drivetrain
Kiggly front clutch pack, translab shift kit, 300m transfer case with Frontline Fab t-case plate, Graveyard rear axle bar upgrade, DSS hd driveshaft, 6 bolt in a 2g kit, Precision Industries stall converter
Gutted, Paul Volk chromoly rear subframe/control arms/toe arms, ES bushings front/rear, KYB AGX struts with eibach pro spring kit
95eclipseSlow
More in 2G DSM
Share this Vehicle
