- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- BLOCK
6 bolt block (line honed balanced)
New Mitsu. OEM 2.0 crank
Race bearings
ARP main studs
Balance shaft eliminated
OEM oil pan
Wiseco 1400hd w/ upgraded pins 10.5:1 E85 - 6656M855AP
MAPerformance Ultimate duty billet steel connecting rods – MAP DSM-UDCR-BS
ARP head studs
OEM MLS head gasket
OEM water/ oil pump
HEAD
MAPerformance stage 5 head
Kiggly beehive valve springs
Kiggly HLA
Topline revised 3g lifters
Crower +1mm intake/exhaust valves
GSC billet s3 cams
Frontline Fab v3 valve cover with titanium hardware
INTAKE
JMF billet intake manifold w/ Thermal spacer
Ti hardware
Bosch DBW throttle body
Magnus Bosch adapter plate w/ thermal spacer
Magnus vanjen Bosch adapter w/ vibrant clamp
Tial Q BOV with titanium hardware
4" velocity stack CAI
EXHAUST
Morrisonfab consolidated divided t4 manifold w/ hot parts side exit (ceramic coated)
Ti hardware
X2 Turbosmart compgate wastegate
TIMING
OEM timing components (tensioner, tensioner pulley, Idler pulley)
Greedy timing belt
Fluidampnr crank pulley
AEM cam gears w/ JDC titanium hardware
TURBO
PTE 6266 DBB gen. 2 (ceramic coated)
Turbo micron filter off housing
Eaton T51R (hks whistle) modification
COOLING
AFCO scirocco radiator w/-16AN fittings
SPAL slim line fans
Sheepey 4in. race intercooler 3in” in/out
Mishimoto -8AN remote oil cooler
Ravenfab custom -16AN fitting swirl pot thermostat housing w/ Mishimoto thermostat
Ravenfab custom -16AN fitting waterpipe
Vamos coolant overflow
FUEL
ID2000 e85 injectors
Vamos Fuel cell (anodized clear)
(New) OEM GS-T fuel level sender
Magnafuel 750 external fuel pump
Magnafuel pre filter
Fuel lab engine bay filter
Radium fuel rail
Radium FPR
Radium fuel pulse damper
IGNITION
OHM Racing Plug & Play IGN-1A “Smart” Coil (Sequential spark) Ignition system
DRIVETRAIN
TRE stage 4 2ga transmission (Cryo treated / Double Synchro Evo III 1st , 3rd, 4th gears )
4 spider center diff
Kaaz rear LSD
Stage 3 comp clutch
ACT streetlite flywheel
Comp Clutch forged steel fork
TRE 23 spline transfer case w/ Magnus cover
DSS aluminum 3” driveshaft
Vamos rear driveshaft loop
Authentic B&M short shifter
Solid shifter bushings
Billet clutch fluid reservoir
SUSPENSION
KW V3 coil overs
Volk front LCAs
Volk rear LCAs
Volk rear toe arms
Volk rear trailing arms
Eaton de-powered rack
Boostedfab cross bar w/ front poly mount
Boostedfab rear poly mount
OBX chassis support bar
RM racing F+R sway bars
DC racing F+R strut bars
Torque Solutions poly motor/poly trans mounts
BRAKING
CTSV Brembo front calipers machined to spec.
Ti brake pad shims
SVT Cobra front rotors
Evo 8 rear calipers
SS lines
Hush Performance brake boost delete
Billet brake reservoir
TUNING/ELECTRONICS
Haltech Elite 1500 w/ p&p harness
Ic-7 dash
Mako motorsports Ic-7 dash mount
Haltech NTK wideband controller
Haltech 4 bar MAP sensor
Haltech 4 port can hub
OHM racing “Tucked” Mil-spec Fuse-box Relocated Harness
OHM racing “Tucked” Mil-Spec Engine Harness
WHEEL/TIRE
18x8.5 ET30 O.Z. Allegerita
Federal 595RS-RR 235/40/18
INTERIOR
Black leather interior rear seat/ panel swap
Corbeau FDX racing seats w/ slider mounts
Autopower 4 point roll cage
Archerfab aluminum spare tire delete panel
Alacantra quick release wheel
Carbon fiber kicker panels
Carbon fiber speedo bezel
Carbon A-pillars
Carbon fiber air bag delete
Weighted shift knob
EVO X DBW gas pedal
Evospec DBW pedal adapter plate
EXTERIOR
Magenta grey paint
Carbonetics csl hatch
Carbonetics v2 hood
Carbonetics doors
SCF carbon fenders
ACW thermoformed rear window
MISC.
Jays alternator relocation kit
Saturn alternator
Custom catch can
Battery relocated to trunk
PS / AC removed
