- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse N/T
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Handling
- H&R -35mm
18x8,75 rims
Bridgestone Potenza 225/40/18
Brembo Evo calipers
Drilled/slotted 320mm rotors
- Parts Wishlist
- GSX-GS-T blackbox Eprom Ecu
Resistor box
oil pan (7 bolt 4G63T)
suspensions (Koni sport or Str-t)
AFR sensor
Oil temp sensor
Pressure turbo sensor
Catback exhaust
Lambda wideband sensor
- Background
- 2GA full converted to 2GB
- Dyno HP
- 145 whp
- Dyno TQ
- 186 lb/ft
