Street Build TewTew the Blue Snail
Ownership Status
Currently Own
Eagle Talon TSi AWD
Drivetrain
AWD
Build Type
  1. Street
eBay Unknown FMIC, NGR BOV, Fluidyne Aluminum Radiator, FIC 1220cc Injectors, Walbro 255 Fuel Pump, Apexi N1 3" Exhaust, JMF Coolant Overflow Can, Old School DSM Green, Ported 2g O2 Housing, Ported 2g Manifold
Mods-Engine
6-Bolt Bored .040 over, Wiseco .040 pistons, Eagle H Beam Rods,BC Springs+Retainers, Delta 272 Cams, ARP Headstuds
Mods-EMS & Logging
ECMLink v3 Full, Innovate LC1 Wideband Gauge, Prosport Digital Boost Gauge
Mods-Drivetrain
Stage 3 Competition Clutch
Feal 441 Coilovers, Evo VIII Enkei’s, Continental Extreme Contact DWS 06 All-Season Tires
Parts Wishlist
Bigger Fuel Pump
All New Bushings
Sunroof Seal
Background
I bought this car May 27th to have a daily street car. So far since I have had the car I have discovered the sunroof leaks, there wasn't a walbro 255 so I swapped one in, and the biggest issue is the shaft play on the 20g turbo. My future plans for this car are just getting it tuned and running decently so I can daily it to work. I took out a loan to buy it so until it is paid off I won't be doing anything major to it. When I do finally pay it off I plan to pull the engine and transmission so I can clean up the engine bay, and wire tuck the wiring. Along with the wire tuck I plan to completely delete all the connectors that are left from the previous owner doing the 6-Bolt swap. Other plans while the engine is out is rebuilding the engine so I can run a larger turbo. I will also be sending the transmission off to be built.
  • Like
Reactions: GST with PSI
TunedUp
Rating
5.00 star(s) 1 ratings
More in 2G DSM
More from TunedUp
Share this Vehicle
