- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 20g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Generic big ass FMIC
2.5" Stainless UICP, 2" LICP
3" Stainless turbo back exhaust
6 bolt intake tapped for npt threads
Bling clutch/brake reservoir brackets from GSX_Dude
Bling caps from JMF
Battery relocation
TiAL BOV (Original Version)
TiAL MV-S 38MM Wastegate
Polyurethane motor mounts
MIshimoto oil cooler
Aluminum Radiator
Generic slim fan (meh)
Megan Short Shifter
Full Custom Fuel Upgrade
-- Walbro 255
-- 8AN FuelLab filter
-- Aeromotive AFPR
-- 8AN rigid fuel line (Send)
-- 6AN rigid fuel line (Return)
-- 680cc Injectors
-- Fuel pump rewire with plug and play custom harness
- Mods-Engine
- 6 Bolt 4g63t Bottom (OE)
6 Bolt Top (OE)
1G Green Top CAS
L19 Head Studs
Balance shaft delete
Custom wire harness - Motor to chassis/ecu
- Mods-EMS & Logging
- DSMLink v3 - Powered via Raspbian
-- Speed Density
---- AEM 3.5 Bar
---- GM IAT
-- Ingersoll Rand EBS
-- Innovate LC1 Wideband
Innovate Dual Function Oil Temp/Pressure
Custom Fuel Pressure & Coolant Pressure Capturing - Powered by DSMUtils
- Mods-Drivetrain
- ACT 2600
Welded center differential
TorqueSolutions Polyurethane Carrier Bearing Bushings
That STM stainless braided clutch line
- Mods-Handling
- GSX_Dude's POM Bushings
--Front Subframe Bushings
--Rear Subframe Bushings
--Rear Diff Bushings
Prothane Front & Back Bushings
K-Sport Coil Overs (Adjustable Height Only)
All new ball joints/control arms
All new sway bay links
Evo8 17" Enkei Wheels
Nexen 245/45's
Stainless brake lines (from stock hardlines to calipers.)
PowerStop powder coated calipers (Front & Rear)
- Parts Wishlist
- All of them.
- Background
- Rescued this from a friend, February 2015. I formerly had this build nicknamed "Kyuubi", but it has since changed to #Sleeper_Beauty. The tan/cream and black color scheme is a tribute to my military service, the purple is a splash of personality.
A lot of restoration has already gone into this car. A lot of engineering has as well. I do not like hose and worm clamps. Its my opinion, and only just my opinion, that any connection with threads will out last any other type - so that is all I try to use. I've also spent a large amount of time ensuring I can simply swap motors to and from my 1G.
Its difficult for me to set a goal right now. I want to be able to drive it to and from work every day (75 miles one way) and also be able to out-douche virtually anything else on the street. I'd like it to be safe for track days. Performance-wise, I don't know what I'll have to sacrifice to get the above reliability. I'd also like to be able to fill in my time slip info below before the end of 2020.
Videos
Official Youtube Channel: https://www.youtube.com/channel/UCQveIlYq9Kd4g5gPVzAs_DA
