- Ownership Status
- Currently Own
- Year
- 1999
- Model/Trim
- Mitsubishi Eclipse GSX
- Drivetrain
- AWD
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
- Self built td06h 25g w/fp 10cm housing, 2200cc Injectors, Walbro 535lph Fuel Pump. Fuelab FPR (6an return with GM e85 sensor), Fuelab fuel filter, Jmf Drag Manifold, ATI damper, Avid Billet Motor Mounts, Saturn alternator, Dynatek ARC-2 w/ C.O.P. 3g Brake Booster w/ Stainless Steel Break Lines, Oil Catch Can, Jmf Small Battery Kit, LC-1 Wideband, Modified 1g bov
- Mods-Engine
- 2.1 4g64 6 bolt (Wiseco stroker 9.5 pistons, Manley 162mm turbo tuff rods.) chamfered crank, Stainless Steel Valves, Kiggly Crank Trigger, Kiggly Valve springs and retainers, Kiggly Hla, Acl (extra clearance) Main bearings, ACL rod bearings, Felpro Mls head gasket, Map l19 Head Bolts, Gsc s1 cams, Gates Kevlar timing belt, 2.4 cam gears
- Mods-EMS & Logging
- Ecmlink V3, Speed Density (4 bar map sensor) Aem Water Temperature, Aem Oil Temperature, Aem Transmission Temperature. Innovate Motorsports MTX
- Mods-Drivetrain
- Auto Swap, Welded Center Diff, Kiggly Front clutch, Modified Valve body w/ Shift Kit, Forced Four 150 Shift Box w/ Dash Display, Precision #6 Torque Converter, 6 bolt Kiggly Flex plate, Solid Diff Bushings, Custom Up/Down Shift Controls
- Mods-Handling
- Cts-v Front Calipers w/ Cobra rotors, Evo 9 Rear Calipers and Rotors, Winter wheels Evo X Powder coated Rims (235/40/18) Summer wheels 17x9 Enkie (235/45/17)
