- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- GT40 Variant
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- AGP 66/72 .88A/R Twin Scroll
FIC 2150cc Injectors,
Twin Bosch 040 Fuel Pumps,
JMF "Race Version" SMIM,
ETS Front Mount Intercooler,
JM Fabrications Top Mount Manifold,
Dual TiAL MV-R Wastegates,
HKS SSQV Blowoff Valve,
AEM Fuel Pressure Regulator,
Full Custom 3" Turboback Exhaust (Self-Built),
Fluidyne Full Aluminum Radiator,
Sparktech Coil-On-Plug Ignition System,
Fluidampr Harmonic Balancer,
Snow Perfomance Methanol Injection (MAP Based)
- Mods-Engine
- JE Pistons,
Carrillo Rods with CARR bolts,
ACL Tri-Metal Race Bearings (Rod and Main)
ARP Main Studs
GSC S3 274/274 Camshafts,
ARP L19 Headstuds,
STM Balance Shaft Elimination,
Kelford Cams Beehive Valve Springs
Ferrea 1mm Stainless Oversized Valves,
3g Revised Lifters,
- Mods-EMS & Logging
- DSMlink v3,
ECMlink Speed Density,
GM IAT to MAF Sensor with an OmniPower 4-Bar MAP,
Prosport Boost Gauge,
Prosport Fuel Pressure Gauge,
Prosport EGT Gauge,
AEM Wideband O2 Sensor,
Hallman MBC
- Mods-Drivetrain
- Fidanza Lightweight Aluminum Flywheel,
QuarterMaster Twin Disk Clutch,
Upgraded Posi/Welded Rear axle
- Mods-Handling
- Powerslot Slotted and Cooled Rotors,
Hawk HPS Ceramic Brake Pads,
Tein Super Street Fully-Adjustable Coilovers
XXR 527 18x8.75 +35mm Offset wrapped with Toyo Proxes4 Plus 245/40R18
