- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Drivetrain
- FWD
- Transmission Type
- Automatic
- Build Type
- Street
- Drag Race
- Mods-Bolt-on
- Weapon-R Dragon Cold Air Intake
SR-S Catback
Galant 90 Amp Alternator
0 Gauge main ground
- Mods-Engine
- Poly motor mounts
Fiav/Isc Delete
EGR Delete
EVAP Delete
Cruise Control Delete
Evo 8 Fuel Pump
Fuel pump rewire w/ killswitch
3kgt VR4 Oil Filter
A/C Delete
Test pipe
1G N/A Throttle Body
450/cc Injectors
482 Maf
- Mods-EMS & Logging
- Openport 2.0/FTDI OBD2 Cable
Innovate LC-1 Wideband (Simulating Narrowband)
Ecuflash/Evoscan w/ Ceddy Mods
Glowshift Red Digital Oil Pressure
3G Ecu w/ Tephra Mods (9653)
- Mods-Drivetrain
- Alto Red Eagle Rebuild Kit
Translab STL-175-HP
Sonnax Manual Valve
Sonnax Shim Kit
Hayden Trans Cooler (don't remember the size)
Whole lot of oem bolts.
Glowshift Red Digital Trans Temp
- Mods-Handling
- Generic Front Strut Tower Bar
Kumho Ecsta XL Platinum
GSX Calipers (front/rear)
Drilled/slotted Rotors (front/rear)
Ceramic Pads (front/rear)
OE Rear Sway Bar (Moog End Links)
3G Master Cylinder
AWD Kyb GR/2 Struts
Tien S.Tech Springs
- Parts Wishlist
- DOHC Swap ( Have 2G 63 head)
E85 Swap
Wire Tuck
- Background
- 2.4 DOHC Turbo, with a built fwd auto tranny. Maybe awd someday.
