- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- HX40
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Drag Race
- Mods-Bolt-on
- Hx40 in turbolab t3 .82 housing
44 mm tial wastegate
Bsfab 3" vband o2 housing
3" exhaust turbo back
Jmf t3 flanged tubular manifold
Fuel lab 818 fuel feed kit
Fuel lab 515 fuel pressure regulator Deatschwerks 1200 cc injectors Deatschwerks 320 LPH fuel pump
fuel pump rewire
Large short route SBR FMIC with 2.5" piping
HKS sqv4 bov
Mishimoto radiator
Saturn alternator swap
10mm magnacore plug wires
4" fp intake
- Mods-Engine
- Kelford 276-272 cams
AEM tru time cam gears
Gates Kevlar timing belt
Kiggly racing beehive valve springs with titanium retainers
3rd gen lifters
Keith black forged pistons
Eagle H beam rods
Eagle stroker crankshaft
ARP main studs
ARP head studs
balance shaft removed
- Mods-EMS & Logging
- Ecm link v3 full
4 bar omni map sensor
GM iat
Autometer boost, water temp, oil pressure gauges
AEM wideband o2 gauge
- Mods-Drivetrain
- Driveshaft shop 3in aluminum driveshaft
6 puck ACT unsprung
3200 act pressure plate
ACT streetlight flywheel
4 bolt LSD rear
Enkei 17x8 45et
Bridgestone Potenza tires
- Mods-Handling
- Koni front struts
Kyb rear struts
Ground control coilover kit
2g front calipers
Stop tech slotted rotors
Stop tech carbon ceramic pads
3sx adj rear camber arms
Pillow ball front camber plates
Braided stainless brake lines
Braided stainless clutch line
- Parts Wishlist
- Aem water methanol
- Dyno Shop Name
- English racing
