1GA plymouth Laser RST
Ownership Status
Currently Own
Plymouth Laser RS Turbo
Turbo Type
GT35 Variant
Build Type
  1. Street
HX40/ T3 BEP Upgraded thrust collar // 10AN Drain 4AN Feed Custom Restrictor // Custom T3 38MM manifold // Tial 38mm Wastegate // DIY 3" vband // DIY custom 3" downpipe // DIY 3" Rear tire exit exhaust // ETS 3.5" STREET FMIC Steel Piping // Tial Q BOV // 1GB TOB w/ JMF FIAV delete // 2G Fuel Rail w/ STM 6AN on Both Ends // 6AN ss Feed from Tank // Fual Lab 6AN SS e85 Filter // Walbro 450LPH E85 Fuel Pump // Bosch 1600cc Injectors // 6AN AFPR // EWorlds 5 stage Electronic Boost Controller // NGK BR7ES // FRH Cast Intake Manifold // 1G NON Cruise Cable // 1GB Talon Rear End Conversion // 1GB Eclipse Side Skirts // 1GA Eclipse Front Bumper Conversion // Drivers Side Custom Motor. Mount bracket W/ Prothane Insert //
DIY custom Body Work and Recent Paint Job Done at Shop //
Mods-Engine
1G Head: stock, Web 546/547 Cams
1G 6 bolt block: Stock
In process: Full Rebuild Of 1G head, manley springs, manley valves, 3G lifters, arp head studs, port and polish, indecisive on cams and leaving block stock maybe.....
Mods-EMS & Logging
ECMLink V3 Full // Omni Power 4 Bar MAP // GM IAT Sensor // AEM Wideband Kit // E Worlds 5 stage EBC // Greddy Turbo Timer // Prosport Bokst Gauge // Prosport Water Temperature Gauge //
Mods-Drivetrain
Ss Line from Master to Slave // Symborski Solid Shifter Base Kit // Solid Shifter Cable Bushings // Fully Built TRE f5M33 FWd trans with karKing LSD//
Stock struts // Eibach Ground Control in Front // Front Strut Tower Bar // New Motegi Racing m125 Racing Wheels with Hoosier Drag Radials //
95DsManiac
More in 1G DSM
Share this Vehicle
