- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Mitsubishi Eclipse GSX
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Drag Race
- Mods-Bolt-on
- Fuel Injector Clinic 1650cc Injectors
Walbro 525lph Hellcat Fuel Pump
Aeromotive Fuel Pressure Regulator
Fuelab 8AN Filter w/ Stainless Element
8AN Braided Fuel Feed Line
8AN Braided Fuel Return Line
4 Bolt Rear End
Solid Shifter Cable Bushings
Custom Dual Ball Bearing RAC Turbo
Custom JDT Racing Turbo Manifold
TIAL 46mm Wastegate
TIAL 50mm Q Blow Off Valve
Custom JDT Racing 3" Aluminum Intercooler Piping
Custom JDT Racing 4" Thick Intercooler
Davies Craig EWP150 Electric Water Pump w/ Thermatic Controller
Custom 3 Pass 1/2 Size Aluminum Radiator with 16AN inlet/outlet
Frontline Fab Water Pump Delete
Frontline Fab Thermostat housing
All 16AN Coolant lines
JMF Drag Intake Manifold
JMF Fuel Rail
S90 74mm Throttle Body
- Mods-Engine
- 6 Bolt Block
Wiseco Pistons
Manley Turbo Tuff I-Beam Rods
22mm Wrist Pin’s - Fluidampr Crank Pulley
Supertech Dual Valve Springs
Kelford 272 Cams
1mm Oversized Valves
Cylinder Head done by FFWD
- Mods-EMS & Logging
- FuelTech FT450
- Mods-Drivetrain
- RRT Custom Built Transmission
- Mods-Handling
- Border Racing Custom Drag Full Coilovers
CTSV 4 Piston Brembo Front Brakes
EBC 13" Cobra Rotors
CTSVBrakeSwap.com Adapter Plates
StopTech Stainless Steel Braided Front Brake Lines
17" x 8" Rota Grid's in Flat Black
