- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Plymouth Laser RS Turbo AWD
- Turbo Type
- GT30 Variant
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Road Course
- Mods-Engine
- 2.3L 6-bolt - Wiseco 9.0:1 stroker pistons, manley rods, oem uncut G4Cs crank, OEM head gasket with ARP head studs, ARP main studs, FP3cams with Supertech Dual Springs and Supertech Valves, Extreme Motorsports/Hogan intake manifold w/OEM NA TB, FP3052 turbo with Morrison Fabrications custom recirculated O2 housing with Tial MVR external wastegate, FP cast exhaust manifold, FP intake, Punishment Racing FMIC with 2.5" piping, Tial BOV. OEM oil pump with straight cut gears, Moroso baffled oil pan, polyurethane engine mounts
- Mods-EMS & Logging
- ECMLink V3, will be set up for Flex Fuel but mostly run on E85 at the track
- Mods-Drivetrain
- TRE Stage 3 Trans w/4-spider, transmission cooler with pump, JNZ Shortshifter, Evo3 Rear Diff mod by TMZ mounted to polyurethane rear subframe bushings, steel driveshaft bushings
- Mods-Handling
- JIC FLT-A2 coilovers, Ground Control adjustable front camber/caster plates, stock front sway bar, modified front control arms with extended ball joints, modified RM rear sway bar, JayRacing ATE, modified rear trailing arm to accept rear sway bar mounting point, Volk Racing tubular rear upper control arms, DIY Swage tubular real lower rod-end control arms.
