- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Eagle Talon TSi
- Turbo Type
- GT42 Variant
- Drivetrain
- FWD
- Transmission Type
- Automatic
- Build Type
- Drag Race
- Mods-Bolt-on
- Old school magnus w/q45 throttle body. Custom t4 divided manifold with twin waste gates. Atomizer 3 400pph injectors. Custom 4in fmic with piping. Tial bov. Ffwd mechanical pump drive. Waterman fuel pump. Custom 4in aluminum exhaust with aluminum muffler.
- Mods-Engine
- Half filled block. Magnus 6 bolt crank. Manley turbo tuff rods w/l19 hardware. Wiseco 1400hd pistons. A1 technologies head studs. Arp mains. Ported 6 bolt head with 1mm ssi valves. Oringed head. Machined by Darren Thomas Racing. Kiggly block gurtle. Modified oil pan pump and filter housing. English racing oil pump drive. Kiggly hla. Relocated alternator. Modified water pump. Kelford 288R cams
- Mods-EMS & Logging
- Aem v1 speed density. Dynatek arc 2. Fuel tech injector driver.
- Mods-Drivetrain
- Dts built 2g transmission. Kiggly 2g in a 1g adapter and flex plate. Precision torque converter. Dss level 5 cv shafts and hubs. Boosted fabrications 2g in 1g kiggly solid mounts.
- Mods-Handling
- Diy coil overs with hypercoil springs anf kyb agx. 26x10 mt slicks
- Parts Wishlist
- Feal 442. Boosted fabrications k member with lca's. Ecu masters black. Digital dash.
- Background
- Originally save from a guy that intended to make a demolition derby car out of it in 2004. Did a street build on it and in 2007 decided to cage it and make a drag car out of it. Finished in early 2009 but never got it dialed in. Played with it off and on until 2011 when it went into storage. At that poi t the rats moved in and made a home. Wires became bedding and seats became toilets. I am currently in the process of rebuilding it.
- 1/4 Mile MPH
- 142
- Dyno HP
- 715 whp
- Dyno TQ
- 430 lb/ft
- Dyno Type
- DynoJet
- Dyno Shop Name
- Abel Racing
- Dyno Session Details
- Dyno session was in 2009 cant remember torque.
