- Ownership Status
- Currently Own
- Year
- 1993
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- HX35
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Morrison Fabrications Divided T3 Manifold
Morrison Fabrications Hot parts kit
Holset HX35 7 Blade Compressor Wheel
12cm Divided Turbine Housing.
ETS 5” Intercooler
ETS 2.5” stainless piping kit
Tial Q BOV
FP 4” Intake
FP Exhaust Manifold
3'' Exhaust
Fluidampr Harmonic Balancer
Fuel Lab Fuel Pressure Regulator
Fuel pressure sensor
Ethanol Content Sensor
Rewired Walbro 535 HP Fuel Pump
FIC 1650cc Injectors
Ingersol Electonic boost controller
Dual Tial MVS 38mm vented external wastegates
Fuel Lab tank to rail w/Fuel Lab Filter
Quick Release front bumper kit
Mishimoto Xline Radiator
Mishimoto 10’’ pusher fan
FAL 12” fan and shroud
Magnus V3 Intake Manifold
S90 Throttle body
- Mods-Engine
- Built 6 bolt block:
ACL Race Bearings
Virgin Crank
Wiseco 9:1 85.5 Pistons
Eagle Rods
Kiggly Main Girdle
ARP Bolts and Studs
Built 6 Bolt head:
GSC Zero Tick Lifters
GSC S2 Camshafts
Kiggly HLA
Kiggly SS Beehive Springs
AEM Truetimr Adjustable Cam Gears
ARP Cam Tower Bolts
ARP Cam Bolts
BC Racing Stainless Valves
ARP head studs
Evo 9 Kevlar timing belt w/oem timing components.
Dual -8an valve cover to RTM catch can. -12an back to FP Intake
NGK BR8ES Gapped .22
Accel Thundersport 8mm wires
- Mods-EMS & Logging
- ECMLINK V3 w/Speed Density, Fuel Pressure Sensor & Ethanol Content Sensor
AEM X Series Wideband
AEM Oil Pressure sensor
AEM Boost Gauge
- Mods-Drivetrain
- Southbend SS/TZ Clutch and Pressure Plate
Jacks stage 1 transmission
Shep stage 4 transmission
De-powered rack and pinion
Power steering delete
- Mods-Handling
- BC Racing coilovers
CTS-V Brembo’s
12.99” Cobra drilled and slotted rotors
18” Evo X Forged BBS
245/40r18 Michelin Pilot Supersport s4 tires
Energy suspension bushings and inserts(front and rear subframes)
Volk crossmembers
Volk active toe eliminator
ST Rear Sway Bar
Ingells rear upper control arms
- Background
- I bought this car bone stock. The car had 125 Miles. It had been garage kept and never winter driven.
The car is next to rust free and very straight.
