Please Support RTM Racing
Street Build The DSM of Theseus
Ownership Status
Currently Own
Plymouth Laser RS Turbo AWD
Turbo Type
GT35 Variant
Drivetrain
AWD
Build Type
  1. Land Speed
FP Super99 ball bearing turbo, Shearer tubular factory-mount header, full Buschur 3.5" exhaust, Tial wastegate, 4" turbo intake and K&N filter, custom RIX intake manifold with extra FIC fuel rail running 450cc and on the head 1200cc FICs, dual Bosch style 340lph out of tank pumps, JMF 10gal alum. fuel cell (not anondized), AEM fuel regulator, AN fittings all around, in line washable filters, factory sending unit in tank for fuel gauge, new oil pump gear and cover, new water pump, rebuilt power steering pump, kevlar timing belt, Jay's alternator relocation, oil filter relocation with oil cooler, JMF coil bracket, Mishimoto radiator, custom 2" through intercooler, etc.
Mods-Engine
HKS 272 cams, BC retainers and springs, Ferrara valves (nitride intake and inconel exhaust), no tick lifters, aftermarket valve cover, Eagle h-beam alum. forged rods, steel floating wrist pin, CP forged aluminum pistons 9.5:1 with Hellfire rings, machined crank, oil clearances checked and all internals blueprinted and dynamically balanced, bored 0.020" over, ACL aluglide rod and ACL tri-metal main bearings, Spectre oil pan and 2g pickup, new piston oil squirters, ARP head studs, "prothane" mounts, fluidampr crank dampener/pulley, new idler pulley, new tensioner, cometic layered head gasket, other cometic gaskets, oil filter relocation, etc.
Mods-EMS & Logging
Haltech Elite 2500 (for all 8 injectors...), AEM "smart coils", Cobb boost control solenoid, factory chassis wiring, AEM oil pressure sensor and gauge, AFR gauge, boost gauge etc.
Mods-Drivetrain
'90 transmission, 22 spline transfer case, ACT 6puck sprung clutch with 2600lb pressure plate, short throw shifter with STM bearings in place of bushings, XACT Streetlite Flywheel with ARP fasteners, that's about it
Some old aftermarket adjustable dampening shocks, 17" rims with 225 tires, just what came with the car.
Parts Wishlist
Eventually want to go for more rally build - beefier suspension with longer travel, new gearbox, maybe a snorkel lol I don't want a monster truck miata but something that'll clear a curb or a log.
Background
Back in February of 2019 I bought it, it was "built" by Buschur many years before that and had a simple fuel leak that once fixed got the car running. Ended up bottoming the pan out on a brick while driving, engine spat some squirters out into the pan and oil starved the cylinders from pickup being smashed into pan which led to a complete engine rebuild; machine shop was supposed to assemble, but after getting jerked around for more than a whole year I just had em finish the machine work and my buddy and I assembled it from there. Hopefully will be all done by the new year!
Funky Geko
More in 1G DSM
Share this Vehicle
