- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- HX40
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Road Course
- Mods-Bolt-on
- Holset HX40 Super 40 T3 .82 hotside
MAP T3 exhaust manifold
DEI titanium exhaust wrap
CMBUILDZ custom 3” o2 housing
CMBUILDZ custom 3” down pipe
STM 4" high flow Filter
4” FP intake
JMF race Intake manifold
JMF coil pack bracket
S90 70mm throttle body
Tial MVR 44mm WasteGate
Tial bov 50mm (8 lbs spring)
Walbro 525 fuel pump & rewire
RC 1200 injectors
Aeromotive FPR
NGK spark plug wires
NGK BPR7ES gapped to .018
STM Stainless oil pan bolts
AEM boost gauge
AEM wide band
Battery trunk relocation - 0g wire
Fuse box relocation
Oil catch can
Aluminum coolant over flow
Mishimoto X-Line aluminum 3 core radiator
Mishimoto radiator hoses
3” intercooler
Short Upper intercooler piping
Lower intercooler piping
Pioneer DMH 1500NEX double din
Dash Designs dash cover
H4 Morimoto LED headlights
LED reverse lights
LED license plate lights
- Mods-Engine
- Balance Shaft Delete
HKS - 272 Exhaust Cam (M006-604)
HKS - 264 Intake Cam (M003-604)
ARP head studs
- Mods-EMS & Logging
- DSMLink full V3
Speed Density
RRE 3 port EBC
Omni 4Bar map sensor
GM IAT sensor
- Mods-Drivetrain
- ACT 2600 6 puck (MB1-XTG6)
FX Chromoly Flywheel
ARP Flywheel bolts
Competition Clutch Fork
TRE 23-spline transmission
STM shifter cable bushings
Solid aluminum base bushings
3D printed shifter bushings.
- Mods-Handling
- Bulfab 3 piece crossmember
Bulfab rear mustache bar
Aluminum rear frame bushing kit
Polyurethane motor mounts
Front Strut bar
Drilled and slotted front rotors
2g gsx brake calipers
Kyb gr-2 struts
SS braided brake lines
Evo 8 wheels
255/40/17 Federal RSR
- Parts Wishlist
- Ohlins coilovers
Roll Cage
2000cc ID injectors
- Dyno HP
- 488 whp
- Dyno TQ
- 389 lb/ft
- Dyno Type
- Dynapack
- Dyno Shop Name
- Road Race Engineering
- Dyno Session Details
- 91 pump gas
331HP/294TQ 23PSI
E85
488HP/389TQ 29PSI
